Home › Forums › Gillion Theme › 5.6
Hi Can I update to WordPress 5.6 ? Hope theme is supporting. Please let me know
Hi @Anusunu,
I hope you are well today and thank you for your question.
Yes, the theme supports WordPress 5.6 and you can update the WordPress to the latest version as described on the below pages.
https://my.studiopress.com/documentation/usage/wordpress-features/how-to-update-wordpress/
https://themeisle.com/blog/update-wordpress-safely/
Best regards,
Shufflehound team
Hi
Everything works fine after update.
But
Search Lightbox not displaying when i click on the search icon on menu bar right side
Could you please share your site URL where it’s happening so that I can troubleshoot it?
i just tested it on my localhost before updating to the live site.
The problem i found.
Your theme works fine when i update to 5.6.
But then i noticed the search icon not opening.
i disabled all the plugins including WP Bakery
Then it worked fine again
then i enabled WP Bakery its working fine.
But after the successful enabling of WP Bakery
when we enabled Slider Revolution it stopped working.
I have many other plugins also Mailpoet,MediaGrid,The Events Calendar Tribe,Yoast SEO same issue when we enable any one of this the search icon and side sliding bar ( for trending news ) stops working
Some scripts are messing up each other.
All others are great except some old post showing in related news
Can you check the JavaScript console for errors when you face this issue?
In Chrome go to “Tools -> Developer Tools” and in Firefox you can go to “Tools -> Web Developer -> Console”
Find information about how to open JavaScript browser console :
http://webmasters.stackexchange.com/questions/8525/how-to-open-the-javascript-console-in-different-browsers
http://codex.wordpress.org/Using_Your_Browser_to_Diagnose_JavaScript_Errors
Let me know what JavaScript errors if any you are getting when you face this issue.
No errors just below warnings only.
But one strange thing i noted that when site opened in safari it worked perfectly.
Then i clicked on a post when the single post opened “search icon pop up not working”
Then i came back to homepage icon not working same as in single post.
only worked on first launch.
<hr />
Here the warning messages in console.
This page uses the non standard property “zoom”. Consider using calc() in the relevant property values, or using “transform” along with “transform-origin: 0 0”.
JQMIGRATE: Migrate is installed, version 3.3.2
Please deactivate the JQMIGRATE Migrate plugin that you are using and also disable the image lazy loading as displayed in the attached screenshot.
I don’t have JQ Migrate plugin installed directly.may be some plugins calling
But i disabled it by adding the custom stuff on function.php.
Bu i don’t see lazy loads instead i have page loader.( Attached screenshot)
The Console errors am getting after JQ Migrate disable as below
jQuery.Deferred exception: e.indexOf is not a function. (In ‘e.indexOf(” “)’, ‘e.indexOf’ is undefined) – “http://localhost:8888/staging/wp-includes/js/jquery/jquery.min.js?ver=3.5.1:2:8483…” – undefined
jquery.min.js:2:31678
<div>[Error] TypeError: e.indexOf is not a function. (In ‘e.indexOf(” “)’, ‘e.indexOf’ is undefined)</div>
<div>(anonymous function) (jquery.min.js:2:31678)</div>
Would you mind if I log in to your site and do quick troubleshooting? If this is ok then could you please temporarily create an admin user account and share the account login details privately by adding them in the box having text “Enter your private content here (only you and forum moderators will be able to see it)”?
I did not updated t0 5.6 on my live site.
i was checking on the localhost before that.
Then please test it by deactivating all other plugins excerpt Unyson and Slider Revolution plugins.
If you need services beyond standard support, we've got your back!
If you'd prefer not to handle the installation yourself or need help getting started, we'll set everything up for you.
We'll help you rearrange sections, adjust spacing, and modify the page structure to fit your needs.
More complex styling changes, theme option modifications, and third-party integrations.
If you need something that's not included in the theme, we can code it for you.
Web design services to create custom sections, pages, and blocks for your theme, plus graphics and visualizations.
Full website builds, custom theme development, or plugin creation from scratch.
We'll provide a clear quote based on what you need. No hidden fees.
