Home › Forums › Jevelin Theme › 503 Error on Installation
Hi
It seems that WooCommerce causes a 503 when I install Jevelin.
If I delete the plugin the site comes up but I do need WooCommerce.
Please assist. Thanks.
Forgot to add that after deleting the WooCommerce plugin, if I try to install it manually the 503 error comes back.
Hi @NewEyeCo,
Sorry to hear of the problem you are having.
Could you please share me the screenshot of the error screen so that I can troubleshoot it?
Have you tried first installing WooCommerce plugin and then Jevelin theme?
Best regards,
Shufflehound team
Solution for this topic
The hosting provider upgraded PHP and that sorted it out. Thanks.
You are most welcome here š
