4 Column Page
Home Forums Jevelin Theme 4 Column Page
Viewing 2 posts - 1 through 2 (of 2 total)
  • Author
  • staterequirement
    Participant
    http://165.227.220.174/insurance-choose-state/
    I am trying to set up a page with 4 columns of multiple buttons in each column.
    The buttons should be in ABC order (which I will create)  from left to right, then top to bottom.
    1234
    5678
    When I set it up this way, the buttons are in the correct order while at desktop width. When the page is at mobile width, however, they move to a single column (which is correct), but they go in the wrong order.
    1
    5
    9
    13
    17
    21
    25
    29
    33
    37
    41
    45
    49
    2
    6
    10
    etc…
    I appreciate your help!
    Hi @staterequirement,
    I hope you are well today and thank you for your question.
    This is happening because you are adding 1, 5, 9 and so on buttons in single column instead you should add each of the buttons in separate columns.
    Best regards,
    Shufflehound team
Popular choice
Professional Developers At Your Fingertips!
If you need services beyond standard support, we've got your back!
Services we offer:
Demo setup
Advanced customization
Layout adjustment
Graphic work / visualizations
Custom coding
Full WordPress development and design
What we can offer
  • Demo setup +
    If you'd prefer not to handle the installation yourself or need help getting started, we'll set everything up for you.
  • Layout adjustment +
    We'll help you rearrange sections, adjust spacing, and modify the page structure to fit your needs.
  • Advanced customization +
    More complex styling changes, theme option modifications, and third-party integrations.
  • Custom coding +
    If you need something that's not included in the theme, we can code it for you.
  • Graphic work / visualizations +
    Web design services to create custom sections, pages, and blocks for your theme, plus graphics and visualizations.
  • Full WordPress development and design +
    Full website builds, custom theme development, or plugin creation from scratch.
  • About pricing +
    We'll provide a clear quote based on what you need. No hidden fees.
Custom Work Form
