Home › Forums › Jevelin Theme › 405 Method Not Allowed
Hello,
I go through a translator, sorry for the translation inconsistencies.
I just installed Javelin version 5.8.2 with the “Startup” demo on WordPress 5.8.2 and PHP 7.4.25.
When I select the menu, during the vertical scrolling, an error “405 Method Not Allowed
The method received is not allowed “appears and blocks scrolling.
Please help me solve this problem which is preventing me from using the theme. I’m novice to development.
I modified the .htaccess file but the problem persists
Hi there,
Can you please share your website link, so we can inspect the issue?
Best regards,
Shufflehound team
The site is under construction. I would like to send you the access codes, but in private.
Sure, you can post it in the private information field.
I just sent you the IDs privately
We can’t see the information. Can you please try to add it again?
Yes of course. I just sent you the information.
Have you received all the necessary information?
Hello, I am coming to the news because I am totally blocked by this problem. Thank you
Sorry for our late response. We still can’t see the login data, maybe you can sent it to our email [email protected]?
Best regards,
Shufflehound team
I sent you the access codes by email.
I look forward to being able to start the customization of the site which is very late. Thank you
Oh, looks like you email got in the spam folder.
We managed to fix your issue, can you confirm that? š
Yes it works !!!
Thanks a lot, that’s cool.
We are glad that the issue is fixed! š
If you need services beyond standard support, we've got your back!
If you'd prefer not to handle the installation yourself or need help getting started, we'll set everything up for you.
We'll help you rearrange sections, adjust spacing, and modify the page structure to fit your needs.
More complex styling changes, theme option modifications, and third-party integrations.
If you need something that's not included in the theme, we can code it for you.
Web design services to create custom sections, pages, and blocks for your theme, plus graphics and visualizations.
Full website builds, custom theme development, or plugin creation from scratch.
We'll provide a clear quote based on what you need. No hidden fees.
